продам тормозную систему M Performance Brembo для E36/E46
шестипоршневые 325x25mm
в комплект входят тормозные диски, супорта, колодки, шланги, переходные рамки
возможна продажа без тормозных дисков
Цена 1000$
г.Одесса
0634414501 Таня
подходят на модели
Make Model Submodel Engine
BMW E36 318i M42 1.8L
BMW E36 318i M44 1.9L
BMW E36 318ic M42 1.8L
BMW E36 318ic M44 1.9L
BMW E36 318is M42 1.8L
BMW E36 318is M44 1.9L
BMW E36 318ti M42 1.8L
BMW E36 318ti M44 1.9L
BMW E36 323ic M52 2.5L
BMW E36 323is M52 2.5L
BMW E36 325i M50 2.5L
BMW E36 325ic M50 2.5L
BMW E36 325is M50 2.5L
BMW E36 328i M52 2.8L
BMW E36 328ic M52 2.8L
BMW E36 328is M52 2.8L
BMW E46 323Ci M52 2.5L
BMW E46 323i M52 2.5L
BMW E46 325Ci M54 2.5L
BMW E46 325i M54 2.5L
BMW E46 325xi M54 2.5L
BMW E46 328Ci M52 2.8L
BMW E46 328i M52 2.8L
BMW E46 330Ci M54 3.0L
BMW E46 330i M54 3.0L
BMW E46 330xi M54 3.0L
BMW Z3 1.9 M44 1.9L
BMW Z3 2.3 M52 2.5L
BMW Z3 2.5 M52 2.5L
BMW Z3 2.5i M54 2.5L
BMW Z3 2.8 M52 2.8L
BMW Z3 3.0i M54 3.0L
BMW Z4 2.5i M54 2.5L
BMW Z4 3.0i M54 3.0L
BMW Z4 3.0i N52 3.0L
135/BMW Performance brakes for your E36 and E46! This kit uses the factory BMW Performance Brembo 6-piston calipers (same as 135i) with E46 330-sized rotors (325x25mm / 12.8") for a bolt on braking upgrade. Everything comes complete - 6-piston calipers, rotors, custom caliper bracket, brake lines, and a pad sensor. Choose your preferred brake fluid and brake pads below (or call us for a recommendation).
Brake rotor options -
OEM Pagid Coated - blank rotors with anti-corrosion coating
Turner/Centric cross-drilled
Turner/Centric slotted
Turner/Cetnric cross-drilled & slotted
BMW Peformance floating and cross-drilled
ECS 2-piece floating with cross-drilled and slotted
Brake pad options -
OEM Textar (same as stock 135i)
Centric Posi-Quiet - nearly dust-free (Turner preferred!)
Hawk Ceramic nearly dust-free
Hawk HPS performance
StopTech performance
This is a direct fit to all E36 and E46 (not E46 M3) and comes with a lot more braking power than standard (especially on non-M E36). Consequently there will be more front brake bias - the front brakes have more bite than before. During normal street driving all you will notice is that the brakes feel stronger. For track driving we recommend a more aggressive rear pad to balance the brake bias or a StopTech or Brembo big brake kit that has been properly engineered for the chassis (not a retrofit).
Requires 17" wheels and wheel spacers may be required depending on wheel spoke design. E46 Style 68 wheels shown are used with 5mm spacer.
